DRW tire filling
#31
#32
The anti theft caps were trashed. With the caps the wheels have to be removed to install (using the special wrench).
Without the caps I can get my hand in the outer hub slot and put the sensors on.
The flow through was not out when I got my kit, and I see no reason to upgrade.
I just ordered the very expensive, but supposedly accurate pressure gauge kit from PowerTank, using their Father's Day 10% off coupon.
Even with the coupon it is very pricey with over priced shipping. But, highly regarded for accuracy.
I have found that if I average all the different pressure gauges I have now, digital and mechanical, and average them, the TST tire monitors are dead on in the range I use, 50-150 PSI.
#33
I had flowthrus for the rear but can't get them on.
I just received the long extensions that secure to the cover,
so I'll call TST and see how to swap out the flowthrus.
#34
Received 3,564 Likes
on
I have used braided extensions and they worked well.
Once I put my tire pressure sensors on, I decided to leave them on year round.
That eliminates physically checking the pressure. A simple scroll through the tire monitor is all that is needed now.
I adjust the pressure seasonally.
55 for the winter and 60 for the camping season.
I use the TST 507 system and am very happy with it. Customer service is excellent.
I'll get the Napa number, I plan on making a double so both tires can be inflated at the same time - pressure.
May even try a "four some"
It kind sounds like the flow thru sensors might be the way to go. With the flow thru on can you still air up the tires without extensions?
I have been thinking about getting the TST507. I have two different trailers I would like to monitor along with my truck. Both trailers run the same air pressure, I was going to install sensors on each trailer, but now that I am typing this maybe I will move the sensors back and forth. I don't use the car trailer that much anyway. But it sounds like it might be a problem when I am not hooked up?
#35
Are you still using the extensions?
this is one of the main reasons for me getting the TST system. My tireTracker did not allow disabling the trailer sensors.
I got two monitors and sensors for both trailers (as their psi were different, 80 and 110). (14 sensors total)
the flow thrus will not fit on the dually rear outer tire. and as my inners are currently lined up with the outers, I couldn't get my hand in for the inner.
I am going to use the Wheel Master braided extensions (just arrived yesterday).
using the extensions (connected to the hub cover) the flow thrus will be a bit longer than I want them to be.
#36
on
#37
The TST is cable of dual tires on two truck axles and three trailer axles.
The monitor scans through all saved sensors, so the trailer not being used would just display a blank.
I use two trailers, camper most of the time, motorcycle trailer only occasionally. I switch sensors.
#38
on
#39
#40
on
#41
haven't got there yet. and hadn't thought about the distance for the tire temp... will need to talk to TST about that
Just talked to Mike at Truck Systems, and he said there should be no significant effect. the temp might be 4 degrees off instead of 2, but you want the alarm to
go off at 150, where normal is 120 and failure is 185. 2 extra degrees off from actual won't matter at that point as the temp should not change instantly from 120 to 185.
He did say to make sure that any extensions actually have a valve core, some don't, and the sensor need to push on the valve core. (the ones I mentioned do have valve cores)
#42
I stand corrected. They are exactly the same. Mine don't come on right away either. Just used them extensively this last week and a half, and noted they have to wake up. Sorry if I caused anyone any confusion.
#43
and the rears set with the valve stems 180 degree apart (right now they are together)
I am concerned about the balance weight of the tubes.. weighs a good lb or more in the box, thus the balance beads. had them on the last dually.. really smooth ride.
#44
Sam, I'm guessing you know most bead installations require special valve cores.
Which bead "system" are you getting?
For those with or thinking of getting a TST TPMS.
The TST sensors are always "on" transmitting the pressure & temperature every 5 minutes.
Should a loss or air occur, the sensor transmits immediately.
#45
No idea the brand. my local truck shop does this all the time.
had it on the last dually too.
they changed brands, to M&R Tire Products beads. Each bag has the valve stem and new cap as part of the kit.
Don't know how this local shop stays in business.. 6 tires R&R, bead broke,
bag inserted, aired up. total $59.75 including an extra bag for in the truck.
