Flareside owners, what is that under the rear fender?
I've been happily dismantling two flareside beds in order to make one good one. I found on both, an odd looking steel something-or-other under the drivers side rear fender.
Take a look (with a flashlight?) Bolted to the wood floor towards the Front, what is that steel-flanged square stock tube's purpose in life?
If you look IN your bed, on the front steel flange, there are 3 carriage bolt heads close together, two hold this thing under the fender.
Thoughts?
Hmm, Don't think so. cause when the assembly is bolted to the fender, the hose is higher and away. Notice your 82 has 6 bed strips. my 84 (and the 86) both have 5 strips!
That could be! since the basic "box" was the same all the back to the 60's. It could be the base for a spare tire rack when Ford made steel fenders, yet I can't see Ford spending the cash to make and install a "useless" chunk of steel that cost $ per unit
That could be! since the basic "box" was the same all the back to 1953.
This thing, whatever it is...has nothing to do with the spare tire mounted to the bedside. See parts catalog pic.
1953/72 F350 Flaresides have 9' beds, didn't require the fender with the cut-out for spare tire clearance.
If it wasn't raining like hell right now I would go out and check my '82 flare side and see if mine has it on the driver side and if it does if theres one on the passenger side as well or not.
