Got a couple questions, trans and possibly coolant related
#31
#32
#33
#34
Well, I finally used the truck again yesterday. I now have a new gauge and lpop. My oil pressure now is exactly what Glenn's is on the highway. I varied from 200-220 temp, and was at 48-49lbs, running 70. Hot idle was a little higher, at 25-26.
This trip was the easy one as far as my race trips go. Half as far and a lot less hills, but it worked good, so I'm happy.
#38
Thanks a nice looking setup Darin!
This is a cheap rake I bought, as least it gives you something to tie ropes to.
#39
Thanks for the comments and link Glenn. I bookmarked the rack. Once I get my new toolbox, air tank for the york, and water meth in the box there isn't going to be any room for tires so I'm gonna need something like that I think. I don't know how soon I'll get the water meth in, hopefully this coming winter, but we'll see how many other projects I decide to do. The air tank and toolbox will be done this coming winter for sure.
#41
#42
Hope your problem is fixed for good Darin. I dont think i have ever read about the lpop getting weak. I havent had any oil problems with mine, but i dont pull like you and Glenn. I have a lpo gauge, but never really documented any readings. I am curious now. Have you guys seen the large hpop reasavoir that riff raff makes and sells?
#43
#44
Thanks Gabe. It happens, though not real often I don't think. I do put more strain on it than most. I'd guess it would be fine in almost any usage, but when it came to really working its just no up to par anymore.
I've never seen or heard of the larger res. Should go peek at that I suppose. I assume its on his site?
