03 expy nav system in a 03 expy swap
Not sure about an '03, as it seems like they're all just a little bit different... the head unit itself should be a straight forward swap. It's the wiring that may or may not be in place in the non-nav truck. And trying to pull all the pieces from the nav truck wiring harness would be next to impossible. You may need to buy that harness separately. Also will need the GPS puck to mount somewhere. That's all I can think off hand. Good luck tho, and I'd be doing the same thing!
