My first Ford pickup....
#271
#272
#274
#275
#280
#282
Did you get the rear wheelwell trim? That shown on the front wheelwells is what Dad's truck had and it is hard to find. HARD. Not many trucks had it and it may be worth something.
Also, depending on what year your truck is you may find the coolant/wiper bottle's bracket, which should still be on the left fender, is what you need. There's a slight difference and the early bracket can be modified to fit the later bottle, but why if you have it available.
#283
I'm going back to the yard tomorrow to grab a few more items. The rear wheel well trim was there but I didn't see how good it was. The fronts are a bit dinged up. I'm adapting '89 doors with power windows and locks and I need the harness that goes from left to right in the cab. There was a lot of the original emissions stuff on the 460 too so if anyone needs some...
The coolant/washer reservoir is still attached to the fender so I'm guessing I don't need the bracket.
#285
