Need help
Need help
Ok guys I am getting ready to head back to the states in a few weeks and I would like to have every thing ready for when I get there. I will be replacing the intake manifold gaskets on my 97 4.2 do to a open IMRC code. I know I will probably need to replace the little rubber clips at the same time and I should probably replace the injector O rings at the same time.
What I need is locations or part numbers where I can order every thing in advance and have it ready for when I get home.
Injector O ring kit
IMRC plastic clips
Intake Manifold gasket
TB Gasket
Valve cover gaskets
Any thing else I am forgetting or should address while I am there.
Also my intake manifold and valve cover gaskets are starting to look a little rough. I was considering having them powder coated or maybe painting them flat black. Not big into flashy on this truck but the factory coating on the manifold is flaking off.
Any advice and help is welcome since I will really need to get the truck running as soon as I get home until I can take leave and go back to VA for the cummins.
Injector O ring kit
IMRC plastic clips
TB Gasket
Valve cover gaskets
Surfnski
1997 - 2003 F150
03-02-2019 10:48 AM
Spktyr
12-16-2016 10:18 PM
fordkid122
03-21-2016 02:41 PM
Brody Olson
32
05-01-2014 08:43 PM
turnrjr
12-14-2008 06:00 AM
