4.9 Hesitation. UPDATES please HELP!
You stated that when you unplug the vac line to the egr, it runs better. Try blocking the egr off completely with a thin piece of sheet metal. This will prevent any exhaust from entering the intake through the egr itself. It could be leaking from the pintle not sealing. Its been known to happen more than you think. The big spring inside the egr could be sticking and not letting the pintle seat and seal off exhaust that is being sucked into the intake. Any leak at the egr is gonna cause you a problem. If it's exhaust leaking into the intake, it'll stumble really bad.
I had to do that on a 5.0 once, I used a Penney
Sorry about the EGR. When I unplug the vac there is no difference, because from what I understand there should be very little to no vaccuum at the egr at idle? I've also tried blocking it right off with a plate, and it doesn't help at all. When I pulled the plugs earlier they seemed pretty dry to me not wet at all. I had drove it home then pulled the plugs before doing the compression test.
It very possibly could cause it would be letting more air into the combustion chambers making a lean fuel mixture.
Okay. I wonder if there's a way I can check the plenum for leaks before taking it apart to replace it? Gaskets are cheap anyways haha. Thanks for the input man, I'll keep you posted on what goes on here. I've been reading the computer can fail too, it's a remanufactured one that's in there now so I'm also wondering if it is going to kick the can. Noticed driving home tonight it had a rough idle until I gave it a little more throttle to pick er back up too.
Right now its a guessing game using commen sense and experience lol also when doing these gaskets, use rtv, I have and have never had a single problem.
#30
