E-fuel conversion help
Byron, I'm using the keyed power wire that was for fuel heater. It also has two wires that go to the battery. With the wire harness I got from Strictly Diesel its long enough to go back to the pump. It has a oil pressure switch (carquest part # ECC 53-33507) and a relay that allows the pump to run 20 seconds to start the motor. After that 20 seconds the pump quits. This is good if you want the key on for some reason. If your having trouble starting, all you have to do is turn it off and back on. On my first attempt to be 'safe' with the Irate system I got a inertia switch that failed so I got this wiring kit. Tomorrow I'm going to get a new op switch.
You can't flood a diesel with the pump running.
Byron, I'm using the keyed power wire that was for fuel heater. It also has two wires that go to the battery. With the wire harness I got from Strictly Diesel its long enough to go back to the pump. It has a oil pressure switch (carquest part # ECC 53-33507) and a relay that allows the pump to run 20 seconds to start the motor. After that 20 seconds the pump quits. This is good if you want the key on for some reason. If your having trouble starting, all you have to do is turn it off and back on. On my first attempt to be 'safe' with the Irate system I got a inertia switch that failed so I got this wiring kit. Tomorrow I'm going to get a new op switch. You can't flood a diesel with the pump running.
DBGrif91
05-21-2013 08:09 PM
mweeps
1978 - 1996 Big Bronco
06-03-2004 07:41 AM
joners
04-07-2004 04:53 PM
oilyspill
03-26-2003 09:58 AM
