Fan, fan shroud and fan clutch part numbers
With A/C is when Ford put a fan clutch on 'em. Adding A/C did not change the shroud. With or Without (Super)Extra cooling package did. So if you have no shroud now,to look it up I would have to know if you have the extra cooling package radiator or not. The shroud's mounting holes would be 15" high or 21 3/8" high.C4SZ8A616B......fan clutch...replaced by EOMY8A616A. Any Ford dealer can order this from Vintage Parts in Wisconsin.C6MY8600A........A/C fan blade....7 blade.....19 1/2" diameter704-786-8139...Dennis Carpenter Ford972-937-2201...NOS Parts LTD.
on
If you use the D4TE fans & clutch they have a larger bolt pattern. Than the earlier fan & clutches models. The water pump snout hole is lager and you'll need a reducer for the smaller FE 5/8" snout. for alignment when going with the D4 that come with 460-400.
The water pump flange bolt pattern is the same as fe's. to the 460, 351,400 with AC is what I'm running 19.1/2" 7 blades 180* thermostat never gets pass 190* much over 185* tho.
If you have AC then you'll need to use a fan clutch for AC not the one for non AC. As they are a little different. The non AC is more of a free spinning one. Where as the AC clutch seems to be engaged all the time for pulling air through the radiator and condensor at stop & go driving..
I was using a fan & clutch with matching pulley 6.3/8 from a 1967 wagon 18" fan for 25 yrs with my supper cool Rad never a problem. Then added AC and changed to a newer bigger clutch & fan..
orich
1968/76 F100/350 360/390: TWO different radiator dimensions, TWO different radiator supports, TWO different fan shrouds.
1968/76 F100/350 360/390 Standard/Xtra Cooling & A/C radiators: 26 1/4" wide x 19 1/4" high.
D3TZ-8146-C (replaced C8TZ-8146-K) .. Fan Shroud / Marked on upper left corner: C8TA-S or C8TA-8146-S or D3TA-DA or D3TA-8146-DA / Reproduced
1968/76 F100/350 360/390 Super Cooling Radiator: 26 1/4" wide x 24 1/4" high.
The radiator support used with this radiator is different as it has a larger opening radius. 1967/72 use different radiator supports than 1973/79.
C7TZ-8146-B .. Super Cooling Radiator Fan Shroud / Marked on upper left corner: C7TA-8146-H or D2TA-8146-HA or D3TA-8146-JA / Reproduced.
Both these shrouds are repro'd by Carpenter. These two Ford part numbers and the dimensions for these shrouds are listed/illustrated in his 1967/79 truck repro parts catalog.
I added the center hole diameter on the fan and changed DC's phone number to an 800 number. Added additional sources for the fan clutch, included sources for the original part number.
C6MY-8600-A .. 7 Blade Fan-19 1/2" diameter with 2 3/8" diameter center hole-Use with fan clutch / Obsolete
NOS PARTS LTD in Waxahachie TX has 2 = 972-937-2201.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 3 = 800-476-9653.
EOMY-8A616-A (replaced C4SZ-8A616-B) .. Fan Clutch / Obsolete
GRIESEL MOTOR CO. in Okarche OK has 1 = 405-263-7242.
PARTS INTERNATIONAL in Farmers Branch TX has 1 = 888-727-0418.
POECS PARTS in Erie PA has 2 = 888-864-9305.
VINTAGE PARTS INC. in Beaver Dam WI has 29 = 877-846-8243.
C4SZ-8A616-B =
HAVEN FORD in Haven KS has 1 = 620-465-2252.
WESLEY OBSOLETE PARTS in Liberty KY has 2 = 606-787-5293.
jaygee15
18
03-19-2019 04:44 PM
CharlaineC
01-25-2016 05:01 PM
