1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Front leaf spring bushings
Old 05-07-2014, 04:02 PM
kc5mhb's Avatar
kc5mhb
kc5mhb is offline
Hi,
Been searching around but not finding any information on the front leaf spring bushing on my 2000 F250 SD 4X4. Its been pulling to the left for a bit while braking. Took it to a highly trusted mechanic and he replaced calipers and hoses on the front. Made it a little better but it seems that once the brakes heat up some it still pulls to the left the closer you are to getting to a complete stop. He came up with two possibilities after much searching: Steering box or spring bushings.
Anyone else have this diagnosis? If so did you replace the bushings and the problem go away?
Old 05-08-2014, 09:25 AM
ATS Junior's Avatar
ATS Junior
ATS Junior is online now
SPONSOR
Worn out bushings could cause some issues up front because things are moving around. Not exactly sure what the issue could be for you. If you need bushings let me know, I have ones you are looking for and they are a direct replacement.
-Junior
__________________
www.ATSsprings.com
Ask About our Ford-Truck Forum Discounts! (1-888-943-8287)
"We sell parts and experience"
Old 05-14-2014, 12:00 PM
kc5mhb's Avatar
kc5mhb
kc5mhb is offline
Problem found!!!! Turns out I have a bad set of brake pads on the front. Being replaced right now!!!!
Old 05-14-2014, 12:13 PM
ATS Junior's Avatar
ATS Junior
SPONSOR
Happy to hear you got everything figured out!
-Junior
__________________
www.ATSsprings.com
green_95
16
06-04-2016 08:38 PM
koski19
10-23-2009 01:34 PM
lhekhuis
11-13-2004 11:23 AM
el conquistador
1983 - 2012 Ranger & B-Series
06-20-2004 09:25 AM
Quick Reply: Front leaf spring bushings
