My first rebuild
#241
Crap! I ordered my fittings wrong, then! Oh well - thanks for the post before I put it together this weekend, bill. I did determine that the threads on an SD Bosch fuel pump are bspt, NOT npt, though!
And now I see what you did with the GP power and the oil pressure switch. That's pRetty slick! Where does that switch screw in? On the oil cooler/filter head? If so does it thread right in or need an adapter? (I'll be ordering fittings tomorrow so might As well order that now as well :-)
#244
I didn't get nearly what I wanted to get done last night. Dinner at my wife's grandparents and watch the kids for a couple hours took most of my night. However I did get the starter back in and connected the fuel pump wiring. I put one of the batteries in so I could do up the window(I found a cat has mad the driver seat home, grrrrrr). When I hooked up the battery I heard the vhf turn on and a familiar voice over the radio. There goes another 20 min I a full out catch up session. Man I want this thing back on the road. I put the ignition to run to check the fuel pump and leaks but couldn't hear the pump run. Wtf. Then I realized I hadn't hooked the ground up. I began to loosen another ground and snap. Efit I'm going to bed lol.
#245
on
1 Post
#248
#251
Nicks setup should work just like the strickly diesel wiring. Once the key is turned to 'Run' and the GPs come on, so will the pump. If the engine is not started, the pump will shut off with the GPs and come back on when there is oil pressure. That 3 terminal oil pressure switch is the key. And I really like how you can use just one relay and fit it in the fuse box. Nice work!
#254
Yeah that double-throw pressure switch makes for a super-slick setup. Especially in our trucks. Looks like Holley had gassers in mind and you're supposed to hook the one side to the starter relay wire. That way you get fuel pressure as soon as you start cranking.
Using the GPs on our trucks gives you that much more of a head start.
To take it a step further, I plan to put a t-valve just after my final filter. I'll use it for bleeding the system after filter changes, but also for filling gas cans for the tractor and generator in a pinch. I'll iust add a double-pole-double-throw switch in the cab that will cut the feed from the GPs and send a constant on signal to that side of the oil pressure switch. Heck, I can even run it right into the aux input on the generator...
#255
on
1 Post
Does it run now just by turning the key on?
