Enhancing mpg on a 460
I just recently bought a 1983 4x4 with a 460 engine. I heard I could increase mpg with headers and a new exhaust system. Is this true? And if so how much mpg could I get for a reasonable price. Also if there are any other tips or affordable ways I can besides laying off the pedal that would be great. Thanks!
Yes the headers will defiantly help, I don't know how much it will increase your mpg. I think your driving style will have alot to do with that.
Also you can look into getting a pre smog timing set pre 1971, your timing from the factory is retarded like 8 deg.
Another thing you could do that is relatively cheap would be to get advance spring kits for your distributor.
I have not tried it on a 460, but I ported the heads on a 351W and changed from a single exhaust system to a true dual exhaust. And it didn't change the MPG at all. The thing ran like a bandit and sounded really good, but the significant increase in exhaust made no difference at all on the MPG.
I don't think headers are worth it either. Your main thing with the 460 will be to lower the rpms. A truck with a 460 was made for pulling loads, and they usually came with 4.10 gears. 3.55's were an option. A overdrive tranny swap would give you measureable results, and give you a quieter ride too, and lower engine wear. You would have to drive it everyday to get any payback in fuel savings, but if you are resourceful, you can find a overdrive tranny and swap it in without much money laid out.
Really shows you how much pedal you're putting into it, and if you can safely keep an eye on it while you're driving, it should help with gas mileage in the long run.
I'll be doing headers on my 460 eventually, plus a true dual exhuast with an H-pipe.
There's nothing one can do to increase city MPG, if you want better hiway MPG, slow down.
The MPG difference between 55 MPH & 75 MPH is a whopping 40%.
It amazes me that people buy full sized pickups, then complain about the MPG.
The pickup itself, and these pickups specifically, have horrible aerodynamics. And then the engines needed to haul a load don't magically quit drinking heavily when running light. Part of that's because when these trucks were designed and built we had a 55 MPH national speed limit, so overdrive wasn't thought to be needed. Nor was a lock-up torque converter on the typical automatic. And the price of gas wasn't very high.
Take all of those factors and turn the MPH, and therefore the RPM, up 20% as we do today and most of these these trucks are gas guzzlers, with the 460 being the worst. But, as Dave pointed out, if we can get the RPM down there are gains to be made. So get rid of the C6 and go E4OD or ZF5 and enjoy both better MPG and quieter cruising. And reduce the speed to the low 60's and you will see noticeable gains.
Tricky Dick initiated the double nickel speed limit.
One can buy one hell of a lotta gasoline for what it will cost to swap the tranny, and the paltry 2-3 MPG gain will only be on the highway.
And btw: 1950/56 Packard Ultramatic's had a lock up torque converter. The 1955/56 version was such a turd that Packard 'nuts' refer to it as ULCERmatic!
When I filled the tank of a Vauxhall Astra for the first time that I had rented from Avis in March 1999, while on a 3 week tour of the UK, the cost was approx $7.50 a gallon US.
