3rd row seat belts out of a Ford minivan. Single inertia ratchet retractor and belts are plenty long.
home made brackets. Lighter weight than most of us would make but definitely no heavier than what the minivan had, and those were spot welded in. A few more pics in my album.
I am considering three-point belts in my '53 F-100. I want to keep the original bench seat. Should I be thinking about some way to lock or otherwise latch the seatback so it doesn't tilt forward? I figure that this discussion is a good place to insert this question.
That's a nice installation there. I only have lap belts in my 50 F1, and have been thinking about what's needed for upgrading.
Let's see more.
das54, what year range explorer? If you were to move the retractor down closer to the crossmember would you still have enough length?
One more question, what size nut did it require for you to weld in? Is a standard size bolt used across several vehicles? The star pattern looks similar in size to what I have seen in both of my 150's and ranger.
I got the mounting brackets for the 48 from Classic Haulers and the shoulder belts from Mid Fifty. They seem to work OK but they could be a bit longer, really got to take a deep breath to get them buckled, or I guess that I could loose a few pounds.
The plates are curved to match the cab, so the only mod to the headliner "should" be making the hole for the bolts. I say "should" be because I don't have a headliner yet.
I assumed that the rubber strip that holds it up in the roof continued down the backs of the door pillars. Does it not?
I see now you have a '56, which is different from the 48-52 cabs. As far as I know, there is no rubber strip in the earlier cab headliners. But, like I said, I don't have one yet.
