Monte's 95 Build Thread
Old 01-13-2015, 09:52 AM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
not a whole lot in the form of aftermarket support for the 300. its not all that hard with a little patience and a comfortable place to work.
lots of turbo threads, one good one on here that I know of. quick google search will give you plenty of ideas, and while it can be done on speed density, itd be better overall for reliability to run MAF.
  #92
Old 01-13-2015, 04:51 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Redneckfordf2502002 is offline
I was trying to explain that to you Matt right when my internet went out. I was trying to talk to Jeremy about Mafs on his ranger.
Trav
  #93
Old 01-13-2015, 05:30 PM
xmontex4's Avatar
xmontex4
xmontex4 is offline
Got ya Trav, I honestly keep getting mixed up with the 04's intake and the 95's intake i thought it was a single large tube until i looked at the first page then that jolted my memory and reminded me that i was thinking of the intake on the 04 lol. I know so much about the 04 that i think it's overlapping when i try to remember something about the 95 when i am trying to recall something like if it has MAF or not.
  #94
Old 01-13-2015, 05:58 PM
Redneckfordf2502002
That is why I make a list of everything the trucks (and bikes) need and I am slowly making lists of the mods. Problem is between me, my brothers, and my sister (I think she might have the mod bug as bad as me) we can't decide what to put in our vehicles. LOL
Trav
  #95
Old 01-13-2015, 07:26 PM
xmontex4's Avatar
xmontex4
xmontex4 is offline
Lol thats a good idea i should do that so i dont mix things up again. Once i learn more about the 95s inner workings and specifics though i should stop mixing them up lol.
  #96
Old 01-13-2015, 07:31 PM
Redneckfordf2502002
I would help more if I knew more about the 4.9L but I don't. If you have any other questions on the rest of it I can try to help you though.
Trav
  #97
Old 01-13-2015, 07:43 PM
xmontex4's Avatar
xmontex4
xmontex4 is offline
Thanks trav, do you guys know the oem block size? I think its 2" is that correct?
  #98
Old 01-13-2015, 07:46 PM
Redneckfordf2502002
I am pretty sure that is correct but I think a few also came with 3" blocks but not positive on the last part.
Also no problem. I hope the 95 ends up looking as good as your 04.
Trav
  #99
Old 01-13-2015, 08:07 PM
xmontex4's Avatar
xmontex4
xmontex4 is offline
Thanks trav! One day it will, she needs a lot of work but she will get there eventually just a little mkre work to do. My plans are to get a rubber floor mat because the current carpwt soaks up the water and salt badly so when replacing that i will clean up the seats and it will be easy ti clean and keep the floor pan from rusting. Also i will be masking and painting the dash black and potentially installing my 08 console in place of yhe broken center seat.
I am also going to plastidip the lower tan two tkne black and swap our the rear blocks and springs for my old SD ones and then lift the from and get some new tires.
Would there be a benefit for an LS in the rear and new gears for 35s? I am not sure how the 300 with the m5od will react to the 35s. It will not be driven highway often its going to be a drive aroind town truck that will ocasionally haul some stuff i the bed. Only time i will drive highway is if i am going offroading or somethi g elsewhere than locally in which case i mag even rKe the 04 lol.
  #100
Old 01-13-2015, 08:13 PM
Redneckfordf2502002
Regear most definatly with 35s. The 300 and M5OD a lot of guys on here have with 35s and no problems as long as they regear.
LS maybe kinda depends. Offroad it will be nice but for around town you probably won't need it much.
Curious how the 08 console will come out. I am having a hard time deciding weather to run buckets or a bench in my F150 since I love the bench a lot but buckets would be kinda nice.
Trav
  #101
Old 01-13-2015, 08:20 PM
xmontex4's Avatar
xmontex4
xmontex4 is offline
I've seen it done before and i want to give it a try, any idea what those guys usually regear to? If i am going to regear anything myself i want to try it on the 95.
  #102
Old 01-13-2015, 08:32 PM
Redneckfordf2502002
Not 100% but I would guess between 4.10 and 4.56.
Also I would be more concerned about the D44 TTB (twin traction beam) holding up with 35s. A lot of people claim they don't like 35s. Most whom go to 35s do a SAS which if I end up going to 35s I will do it but again another not decided.
Trav
  #103
Old 01-13-2015, 10:02 PM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
Wow a lot goin on in this thread since I last checked...a few hours ago....
35s will be perfectly fine with the 44 ttb and light 4wheeling/street driving. If you were running 35 boggers and gettin violent then it'd be suspect. I ran the 44 with 35s for 3 years, and I did get violent. Granted, it had a wimpy 302 during that time so that helped. It never blew, I replaced it after it was worn and needed a rebuild. What'd I replace it with? Dana 50, ran 37s with that and beat the hell out of it for another 3 years. Ran it for 6 months with engine in my sig, then when it also needed a rebuild in went the kingpin because I had it. If I didnt, I woulda rebuilt the 50.
Moral of the story; you'll be fine with 35s, especially at stock power.
  #104
Old 01-13-2015, 10:08 PM
Redneckfordf2502002
I guess I was told wrong then. Maybe I will have to do a little looking into that then.
Me, Matt (Monte), and Jeremy (wizkid) all can get a thread moving. LOL
Trav
  #105
Old 01-13-2015, 10:10 PM
xmontex4's Avatar
xmontex4
xmontex4 is offline
Haha thanks man that's good to know, what do you think about gearing with 35s? I am not going to go crazy it was just a cheap truck that i dont mind getting aggressive with lol.
Yeah trav is right we can fill pages in a few hours of either good conversation or nonsense lol
Quick Reply: Monte's 95 Build Thread
