2001 5.4L moisture in Coil on Plugs causing misfire
2001 Navigator 5.4L - I had to replace one of the coils on the driver's side some time ago, and since then, I keep getting moisture under the coil cover that eventually causes a misfire. If I remove the cover and let things dry out, then the misfire goes away.
I don't drive this truck much. Where is this moisture coming from? Is it getting under the cover from outside, or is something leaking/cracked/broken internally?
OK, it is up front so it should not be water leaking down from the windshield wiper cowl.
Check color and greasiness.
Could be either reason you mentioned about intake or a porous head casting.
Don't let it take out the coil drivers in the ECU. Factory manifold replacements only if cracked.
Carolyn Peters
1997-2006 Expedition & Navigator
05-03-2013 08:44 AM
