Rear fuel tank filler neck
Hey all. I'm getting ready to build the fuel tank for my truck. I have looked high and low for decent rear tank filler neck. I need the non filler door metal fill neck. All the ones I come across are rusted out. I want to use the blank hole in the rear of the bed of my highboy to keep the filler looking semi stock. If anyone has a line on one I'd appreciate it.
I was in the same predicament about 2 months ago. Found an NOS one on ebay ($60). I think Filler Neck Supply Co. also makes them (or refurbishes) but they are a bit more expensive. http://www.fillernecksupply.com/servlet/the-2296/73-74-75-Ford/Detail
What's the difference between the front one and the rear? That picture looks identical to what I used. Did run into a little screwing around with the rubber filler hose due to the 33 gal Bronco tank instead of the stock tank. My filler connection at the tank is not straight across from the hole in the bed. Read something about the Bronco tank fill point being further back than stock.
Damonj
11-20-2020 08:30 PM
jaymmc
10-21-2009 11:12 AM
