Rustproofing holes drilled in door for mirror
I found a set of type 8 mirrors for my truck at a salvage yard. In order to install them, I have to drill 5 holes in each door. Most of the mirrors that are attached to doors like this have "rust drip" where you can see a rust stain from the hole. Some are just plain rusted completely out. The bolts are stainless torx screws, and there is some type of washer/gasket for each hole. They are not rubber, but teflon or hard plastic of some sort. So, is there any kind of rust preventer I could apply, or would rubber grommets work best, or maybe even silicone caulk applied at time of installation. What do you think?
joegeds
08-14-2017 07:20 PM
