'87 carbed 460 cam timing
on
I believe the '71-'87 motors were retarded 4 degrees for emissions reasons. Correct me if I am wrong please.
I need to replace the front main seal, and I'm going to pull the front cover off to check the timing set. I do not need to worry about emissions testing here(the air pump has been off since the 90's.)
Would this dinosaur(CCLB) benefit from a straight up timing set? I assume it would, but wanted some input before buying the new gear set if the old one is ok.
BadDogKuzz
03-08-2015 11:24 AM
Big O Dave
11-26-2005 08:40 PM
jwrboss302
09-08-2004 01:00 PM
tturvy
09-27-2003 10:27 PM
