front axle blowing out 90wt
The breather hoses (front & back) are there to relieve the pressure caused by the angular momentum of the diff internals whipping around the 90 grade. (I'm sure we all know this....just thinking out loud here). But, there's no way there would be any pressure build up in the differential(s) at idle, when the vehicle is stationary. Inside/outside pressure are at equilibrium...
Something sure is a-miss here....that hose should be the only thing coming off your axle....except for the brake lines.
There's no way the hose and nipple are clogged? I took mine (breather nipple) out and drilled it for a little larger diameter and better breathing.
well i dont have a clue what to do with this one. the hubs turn free in and out so i dont think anything is stuck. i had the truck running for less than 5 minutes and it started to leak. this issue and tranny issue are driving me nuts. I even called the local axle shop and he told me i was crazy. It can happen.
Can you maybe post a pic or a video of your problem. That may help us help you better diagnose the problem. At this point I'm thinking it may not be your axle. The only time it should build any kind of pressure is when in 4x4 and rolling down the road or on a trail. Simply starting and running the engine with the truck stationary simply shouldn't do anything. They only way that could possibly do that is if you some how have a vacuum or pressure line hooked from the engine to the axle.
i will try to post a video but not sure if i can. I know this sounds really out there but there is nothin hooked to the axle but the breather hose and the brake lines. I have no clue what is causing the front axle to build pressure. it might be a few days, have to pull the tranny out and have it fixed. dont know what happened to that.
1)Is there anything on the end of the breather hose? sounds crazy, but I had a 1-way valve on one of my trucks, which was supposed to prevent anything entering the line(water), but allow for pressure to escape. What it did was act as a syphon, and suck fluid out. I solved the issue by removing the piece on the end, so It was just a bare hose.
2) imilarly, if there was a section of tube inside the axle attached to the breather, or if oil managed to get into the breather tube the mere trembling of the vehicle under power would create a syphon scenario.
3) The only other thing I can think of is the type and weight of the oil. check this link out.ZJ D35 Axle Vent Tube Syphoning Off Differential Fluid.
Pop the plug on your diff, right after you get done with a drive. Check to see if your oil is foaming. Then, while the plug is off, blow air through the breather to try to drain the line.
Other than cleaning the line, or changing to a different kind of oil, there's nothing else I can think of. very strange
#29
so come to find out that the diff was messed with some time back a few years. turns out a rear diff cover from a car will fit the d44. so the fill hole was way to high and that was why 90wt was blowing all over the truck. sorry to get everyone in a bunch over something that was done years ago and i didnt know about.. Thanks for all your help.
