203* thermostagt
Old 04-05-2014, 03:44 PM
diehardstroker's Avatar
diehardstroker
diehardstroker is offline
203* thermostagt
What would be normal temps with this?
Old 04-05-2014, 04:01 PM
ebbnflow's Avatar
ebbnflow
ebbnflow is offline
My oil temp is 208-215 with the 203 thermostat.
Old 04-05-2014, 04:50 PM
diehardstroker
And that's just cruising around? I didnt realize this till now but when I put the t-stat in, I put the o-ring in first then t-stat and then t-stat housing. Then looked at my old water pump and the t-stat was in first then o ring. Should I switch them so its like it is on the old water pump?
Old 04-05-2014, 04:58 PM
mueckster's Avatar
mueckster
mueckster is offline
I would put it back with the square cut o-ring on top of the thermostat.
Old 04-05-2014, 05:19 PM
t.scottNDU's Avatar
t.scottNDU
t.scottNDU is offline
I'm also between 208-215 EOT on the highway. I'm surprised you aren't getting leaks with the gasket situated like that. I would put it on top as well.
Old 04-05-2014, 05:27 PM
diehardstroker
Well its not leaking I've driven it about 30 miles with no leaks I saw 207 eot cruising at 75. Just wanted to see what was normal
Old 04-05-2014, 05:40 PM
The Brad's Avatar
The Brad
The Brad is offline
I took mine out because I was seeing 220-230 while towing 10k in 60-70* temps. That won't work for summer towing. I went back to stock 195* and don't see any different eot while cruising, but I haven't towed yet.
Old 04-05-2014, 06:04 PM
t.scottNDU's Avatar
t.scottNDU
You're fine, I'm just surprised is all. Especially with as finicky as the thermostat/housing can be with leaking.
I haven't towed with the 203 yet, but I'll probably come to the same conclusion and spring for the 195. The short stem 203 was just most readily available when I did my T444E pump.
Old 04-05-2014, 06:10 PM
diehardstroker
I put some rtv around the housing that's for water pumps and related items. I also torqued it to spec so I imagine its gonna be fine. I typically don't tow much so I don't have to worry about that part.
Old 04-05-2014, 07:21 PM
mueckster's Avatar
mueckster
I barely saw EOT's that high in 90-100° summers with my Dieselsite 203° stat. Mine usually peaked around 200° at those cooler temps.
Old 04-05-2014, 07:42 PM
diehardstroker
When I'm driving through town it stays under 200 but with cruise on at 75 it gets up around 207*
Old 04-05-2014, 08:11 PM
scotttahoe's Avatar
scotttahoe
scotttahoe is offline
Do remember that optimum running temperature is 215*.
Old 04-05-2014, 10:50 PM
Jmatthews's Avatar
Jmatthews
Jmatthews is offline
is a BAAAD MAN
And at 203* the thermostat is just as wide as a 195* is.
Old 04-06-2014, 08:36 AM
diehardstroker
I didnt know it was that high for the optimal temperature.
Old 04-06-2014, 09:20 AM
jr2000sd's Avatar
jr2000sd
jr2000sd is offline
Would you guys recommend the 203° or the stock 195°? Did your motor run any better with the 203? Any better mpg? I see about 185° oil temp driving around and i wannd bring it up just dont know witch to run 203° or 195°........thanks guys
Quick Reply: 203* thermostagt
