1999 4 cylinder Ranger engine miss
I have recently purchased a 1999 Ford Ranger 4 cyl, 5 spd with a/c and 65k miles. The truck seems to have a slight miss (slight bucking ) at higher rpm's like the timing is slightly off. The timing is not adjustable on this unit I understand. I installed new plugs and the wires will be next unless someone has an idea as to the problem.
