1964 Ford F100 Restoration
#77
#83
Hey. Do you have any tips for getting my hood to come down level at the cowl? Yours looks pretty dang good! I have already got the hinge almost down to lip on cowl and not much more room. Original hinges. My hood sticks up maybe 1/8 to 1/4"....
Can kinda see it here but more so on the body line at bottom of hood.. Any suggestion are appreciated.
The following users liked this post:
#85
look at where the hood hinge bolts to the hood , you will see at the front bolt the hood brace is starting to crush in just a bit , just 1/16 of an inch of it crushed in will cause almost a 1/4 inch difference when the hood is closed because it prevents the hinge from lowering to its full amount . add a large diameter fender washer between the hinge and the hood on the front bolt only for a temporary fix . more permanent fix is to repair the hood brace . This it most times cause by a tight hinge or rusted up hinge and forcing to close instead of fixing the hinge problem .
#86
RMK73 I used replacement hinges from LMC truck. My old hinges were shot and the hood sat up about 3/4 of an inch before I tore it apart. You could push the hood down in the back and it would just come back up. Pivot point holes were oval. I am not happy with the way the new hinges work. Springs are lighter than original and 1 hinge is stiffer than heck and the other has a lo of slop in it. I found a set of brand new NOS hinges and am going to put them on this spring. They are a lot better quality than the china knock ofs. We had to modify the holes and use shims to get it to look as good as it does.
#88
