Where do I find the material to go between the spring leaves?
Old 03-22-2014, 06:35 PM
wavetrain75's Avatar
wavetrain75
wavetrain75 is offline
The slippery "tape" (for lack of a better term) that you put between the spring leaves to quiet it down and soften the ride a bit.
I've got the rear springs apart on the 49 and will take out every other leaf and put the tape between the remaining springs.
The proper technical name would be helpful too.
Old 03-22-2014, 06:47 PM
clintonvillian's Avatar
clintonvillian
clintonvillian is offline
speedway - leaf spring liner
spring liner from Speedway Motors, America's Oldest Speed Shop
Make sure to grind off any grooves left from the old springs. If you don't it will rub holes in the liners at that point. Cut them down with a grinding disc and smooth with a flap disc. Don't over heat them.
Old 03-23-2014, 01:01 AM
dmack91's Avatar
dmack91
dmack91 is offline
I just ordered some from Classic Haulers/Mid-fifties. I think it was $21 for enough to do a pair of springs.
Old 03-24-2014, 12:00 AM
fixnair's Avatar
fixnair
fixnair is offline
I bought mine from a local spring & brake shop. The stuff I used was made for leaf springs and is called delrin. You have order it to suit the width of your springs and it came in a roll. You just cut each piece to length.
zstyle01
05-22-2007 09:44 PM
StarFox
09-20-2004 05:31 PM
1952
10-14-2003 06:45 AM
cheappower82
09-16-2003 02:54 PM
ddurant
07-17-2003 01:25 PM
Quick Reply: Where do I find the material to go between the spring leaves?
