Atomic led cab lights
Very nice. I was looking at those recently because of the stobe option to replace my goofy magnetic mount amber strobe. A few questions:
Do yours strobe, separately from the vehicle flashers?
If so, can you elaborate... Like do they work just as running lights and flashers, and have a separate strobe switch?
I assume your truck did not have rooftop markers - other than the drilling agony, how did running the wiring go?
Thanks.
Thanks.
Cab Light Install With Pics - Ford Powerstroke Diesel Forum
F250 Factory Clearance Light install
This is 2 of the sites I used some of the wiring will be different because of the extra wire per light for the whelen flasher module.
Thanks.
Thanks.
The drilling was not so bad but I did measure probably 10 times. As far as wiring I ordered the harness from atomic. It was very easy to hook up to each light and run it down the drivers side to the flasher module that came with the light.
I was wondering how your lights are holding up. I installed mine back in 2012 and right at 2 years one of them half the LED's stopped working. If I tapped on it they would work for a few days. Then a second one started doing it as well so I contacted Atomic and they stated they only have a 2 year warranty and I filed at 2 years 2 months. They offered to sell me the updated model for $150. After spending $240 on the 2 year old ones I didn't care to spend another $150. Now only half of the LED's on each light work and I guess the gaskets dried up because I get water poring in during a heavy rain or car wash.
ron's power stroke
38
11-24-2010 07:07 PM
yield2s
05-13-2007 10:33 PM
