is it worth fixing
Old 03-20-2014, 01:24 PM
recovery7778's Avatar
recovery7778
recovery7778 is offline
is it worth fixing
Well to start I have a 00 Ex, it currently has Gibson exhaust, 6 or 8 inch lift, bushwacker cutout flares, 42`s on 20`s, interior is perfect, updated front end, updated mirrors,....
Here is my problem it's a northern truck, was never rust proofed. Truck was barley driven, but it sat outside. Now the cab corners, rockers, inner rockers are shot, ..so I went to 2 different shops, first shop said at least 10k to fix, 2nd shop was about the same, so here I am should I try to fix it or let it go and just use it till the body falls n half...
Any and all feedback is greatly appreciated...
Old 03-20-2014, 01:29 PM
FUFIMI's Avatar
FUFIMI
FUFIMI is offline
It depends on how much time and money you have to throw at this thing. For 10k you can probably buy a nice rust free rig from another state and swap your parts to the new vehicle.
Old 03-20-2014, 01:31 PM
ufvj217's Avatar
ufvj217
ufvj217 is offline
Post some pics. Shops are likely going to be expensive. If you have any buddies that are good with stuff like that, you'd likely save a ton of money.
or consider a body swap. Is the frame good? If so all you'd have to do is reinstall the cutout flares on the new body
Old 03-20-2014, 01:33 PM
SummerBaby250's Avatar
SummerBaby250
SummerBaby250 is offline
It's probably worth fixing if you plan on selling it?
Old 03-20-2014, 01:34 PM
enormiss's Avatar
enormiss
enormiss is offline
Did you see this post
https://www.ford-trucks.com/forums/1...-rust-ugh.html
Outer rockers dont appear that difficult provided theres enough inner left to attach to
Old 03-20-2014, 01:40 PM
LivingLarge's Avatar
LivingLarge
LivingLarge is offline
What engine? Is it 4x4? Mileage? Is it a limited trim?
Old 03-20-2014, 02:04 PM
recovery7778
Frame is perfect, it's 4 wheel drive, it's a xlt, white with the gold/bronze mouldings on the bottom part of the doors, had matching fender flares....
150k miles on the v10, heads have been redone.
Wish I had pics on this tablet
Inner rockers are gone so there's nothing left to weld to, might look into the adhesive bond for metal
Old 03-20-2014, 02:11 PM
FUFIMI's Avatar
FUFIMI
FUFIMI is offline
Since the frame is perfect I would look into doing a body swap
Old 03-20-2014, 03:07 PM
ExxWhy's Avatar
ExxWhy
ExxWhy is offline
Received 2,148 Likes on 565 Posts
Thumbs down
Too many rust free specimens still out there for that kind of $$. It will be a never ending battle. I'ts called the rust belt for a reason.
Old 03-20-2014, 03:33 PM
LivingLarge
For that kind of money, I would buy another and swap out the parts that I wanted from the rusted one. Then sell the old one to recoup some of the money. There's plenty V-10's out there cheap.
Old 03-20-2014, 03:46 PM
Big Sky's Avatar
Big Sky
Big Sky is offline
After looking at what he did and glued the panel in instead of welding it looks pretty straight forward. Might even try to get a rattle can with what ever color you have and do what he di. I like it.
Old 03-20-2014, 06:56 PM
jayjjcc's Avatar
jayjjcc
jayjjcc is offline
Find a 6.0 and swap the body
Old 03-20-2014, 07:43 PM
fatherdano's Avatar
fatherdano
fatherdano is offline
silly. unless your first child was delivered in it. 10-12k?
you can do much better for an entire new rig..
good luck
Old 03-20-2014, 07:50 PM
FUFIMI's Avatar
FUFIMI
FUFIMI is offline
Come to CA and buy a rust free truck and swap your lift and nice interior.
2000 excursion
Old 03-20-2014, 09:03 PM
recovery7778
Trucks out there in California, are a lot cheaper than here, found one already lifted a few goodies for 7500, I'll defiantly watch the ads out there, I've got another 8 weeks before I can travel, just had back surgery, but looks like a plan for the summer
Thank you
Quick Reply: is it worth fixing
