AOD rebuild
It will be mostly stock and I save about $60 so I think I'll go with the 1600-1800 converter.
This question is more or less directed at Conanski, or someone with experience trashing a trans. I have a can of trans flush but I'm worried about little aluminum pieces staying in the radiator and getting back to the transmission. Do you think an inline filter like this would work or did you buy a new radiator?
http://www.summitracing.com/parts/WIX-58964/
When I did my c-4 in my '71 a friend who ran a trans shop told me to be sure to flush the cooler and lines with kerosene. He said get a cheap drill driven pump from Lowes and some clear tube and connect to one side of cooler and let other line drain into a pan. Run about 1 gal of kerosene thru it or until clean. Then blow out kero with air, should be it.
on
So what flexplate did you use this time? I'm gonna be swapping my c4 for an aod. But I'm confused on the flexplate issue.
I have a 351C with the 28oz balance. Is the backspacing right on the c4 flexplate or do I need to find a different one?
And was the early c6 flexplate different too? I ask cuz I've got another AOD 351C combo that is together with the original C6 flexplate. Is that gonna cause a problem?
on
No you can't use a C6 flexplate with an AOD, it will bolt together but it pushes the TC back too far and the pump self destructs the instant the engine is fired for the first time and sends metal shavings throughout the trans. The 351w/AOD combo was used in the mid '80 crown vic so that is what you need to get a flexplate for, the windsor also has a 28oz imbalance.
I did further research and found out that the Monster torque converter was actually made by Dacco so that is a no go. I did some more looking and found some good reviews on Dirty Dog converters with a stock style replacement that I think I'll order after talking to Allen on Monday.
Converters - Ford - AOD - F-52 Stock AOD converter - DirtyDog Performance (Powered by CubeCart) - AOD Stock replacement
Why are you against daaco. I've used them a number of times in race cars and my trans builder that does a lot for the local drag strip, uses them 2/3 of the time. I never had a problem yet. I have a 540hp 351 with a 4000stall (3000lb 68 mustang), a 360whp 390 with a 26-2800 stall (4100lb 67 mustang) and my only complaint is the 4k is too loose.
#30
