building my engine
Old 03-15-2014, 10:25 AM
1994curtislowef250's Avatar
1994curtislowef250
1994curtislowef250 is offline
building my engine
I have a 94 351 going in a f250 the engine has been honed cleaned all that jazz the heads I had were cracked and not seating so I got re manufactured e7te I order comp cca-35-308-8 roller cam I know I need to get springs I'm just going to get the Alex auto parts springs. And I'm wondering if my factory length pushrods will work. It's stock roller rockers
Old 03-15-2014, 10:32 AM
Conanski's Avatar
Conanski
Conanski is offline
Nothing extra needed to put that cam in the motor but the heads will need matching springs/locks/retainers and you will need to have everything checked to ensure there is no coil bind out to 0.550 lift.
Old 03-15-2014, 11:15 AM
1994curtislowef250
Old 03-15-2014, 02:31 PM
Conanski's Avatar
Conanski
Conanski is offline
You don't have GT40p heads though..
Old 03-15-2014, 04:03 PM
1994curtislowef250
Copied the wrong ones. SB Ford, GT40 Drop In Valve Springs Kit, Hyd Roller, Select from .560" or .600" Lifts - Alex's Parts Sales these say gt40 but my valves are the same length so they should work roght?
Bootlegger's Deluxe
05-04-2018 12:41 PM
My4Fordtrucks
49
11-06-2017 07:59 AM
jsutton
10-24-2017 02:50 PM
jaye
09-26-2011 03:08 AM
66ford400
05-30-2005 02:50 AM
Quick Reply: building my engine
