E4OD Issue (Surprise)
On the way home from the store, truck warmed up, it shifted into OD at 37ish MPH and it felt like it was vibrating a bit. So at the next light I took it out of overdrive and got to 40 and it felt okay.
Then a couple miles down the road, I noticed an odd noise and thought it was car next to me. Same noise at the next light - like a fan blade hitting something.
Put the truck back into OD and it vibrated again. Did this at as I accelerated at every light or stop. Seemed to be tied to engine RPM a couple times. It's a hard feeling to describe. As if a tire is slightly out of balance.
Thoughts?
Thanks
Thoughts?
Thanks
I think the first thing I would suggest is that you pull the inspection cover off between the engine and transmission and make sure that you aren't dealing with a cracked flex plate. That sounds a lot like a cracked flex plate to me. Make sure that you can't move the ring gear forward and back and that everything looks good and tight in there.
That's a pretty common swap. Was the truck originally a ZF truck? You have all the necessary parts and pieces to make the swap (PCM, Trans crossmember, driveshafts, clutch pedalbox,etc)? Auto vs Manual debate aside, the ZF is a more "bulletproof" setup in my opinion. This coming from a guy that currently needs to replace his clutch, (me) lol.
Floor pan and xmember can be modified. I currently run both modified from an E4OD. Although I would prefer (and I'm currently looking) to run a true ZF xmember, just letting you know that can work. The floor pan is just a simple cutout.
