Tuner & Timing Chain Issues?
Hard to explain the exact sounds I'm hearing but from what I can tell the only times I hear it is under load when running 87 tow or 87 performance. I do not hear anything unusual when in stock mode and I have not noticed any sound when I'm in 87 economy. I don't know if this helps at all but I know that there has been no adjustments or replacements of timing components thru the life of the truck. Again it's a 2006 with 93,000 on it. Best I should probably have the mechanic take it for a ride with the tunes on which I will do soon.
Quite honestly I don't even know, I just know my engine makes some really funky noises when running the tunes, It could be a combination of pre detonation or ping as some call it, Mine makes some weird sucking sounds from the intake as well. I chose to not run the tunes on my motor for this reason and only use it as a scanner now..
jake00
Modular V10 (6.8l)
23
12-17-2008 11:22 PM
