WHats the difference? is there any? motorcraft gold vs regular prestone coolant
As long as ut is a long life cooland and it is compatible with ford's specs it wouldn't be a problem i use the peak global lifetime, since you are going to flush and change the fluid go for a longlife or ekvivalent since it has all the additives and sca's so you only need to check that on a year or 2
Powerstroke_wannabe
11-16-2009 06:19 PM
