Starting my Coe build starting right is half the battle
Seth, when I first saw that Oregon truck I thought it was yours! Almost identical look. You can also include yourself in that last statement as well......your truck is very cool.
It is a Coe one i bought and didnt build. Thats to keep me interested in the build and motivated to finish my next one exactly how i want it. Its great to have the reference to look at to see how it should be all toogether. Doesn't every man deserve more than 1 COE?
calculating the cabs
Ok my plan of course is to put the cab on a 91 f250 chasis. I have measured the wheel base of the donor as 157" and from the Coe specs from front wheel to back of cab is 50" the bed is 57 " from front of bed to rear wheel center so that should give me 50" I will be cutting the cab but in will be going back on aft of second cab for the back window. What is the lenth of the 49 f7 cab? sounds like i have room for an opera window. All imput welcome
The doors are 36" long. So that gives you 14" of extra space.
Personally, I would look for another more COE friendly chassis with the correct wheelbase. Are you using the F250 chassis just because you have it? It could turn out to be a bigger headache than it's worth.
If you are set on using it, I would shorten the wheelbase. Having a large space between the front and back doors would make the cab look really long.
That is just my opinion of course.
Thanks tinman Of course i was kidding about the opera window. I purposely bought the xlt lariat for this because of the low mileage motor, It had damage so price was right and wanted to keep a full 8 foot new style bed. I seen that they did this with the 158" wheelbase original frame. The look i was going for was sort of the grave digger type 4 wd high and noticable. When i build the 51 it will be low and sweet. I know i needed some kind of transition from 64" coe cab width to the 71" truck bed width but i really dont want to do a sleeper like others. I can shorten it the 14" but i think i will look at building a custom bed first
Yes great idea I was needing the transition like dovetailing the bed to be narrower at the cab from wheel wells to look good with the cab and 57 " was a short maybe noticeable distance but 71 " I think I can hide the 3.5" on each side much better. I do think that the cab and bed need a balance so computer image would be great but that's beyond this old boys talent
preparing the work area
Well i bought 3 of those big wheel carts like home depot has. But i have yet to put the cabs on them. Garage space is critical and everything must be mobile.I even need to install a steering box on the donor truck. I have a trailer im trying to keep most of the parts in for now. We still have snow on the ground here so the frames come home next month. Im not getting alot done between cold and having to work a regular job all the time, The nerve of them people "dont they know i trying to build a coe" come on retirement.
#29
planning the cab bed combo
Well after Tin man told me the cab may look too long got me really thinking. (He really knows alot and I value his opinion ) I really dont want to have a truck that is unbalanced between cab and bed. Many of the ones i seen with 12 ft beds and some with sleepers just dont have that appeal to me. This is such an enormous project for me to do from my home garage that I am trying to get it right from the begining hence the name of the thread. so im throwing some ideas out there for the sharks to bite on. Let me know what you gentlemen think, I am looking at the option of a low bed like in the pic, So heres the donor truck too My thought was 5" extra on cab 9 on bed.
#30
Great idea to have a plan BEFORE you start.......I tend to address problems as they arise, which is kinda backwards.
Since you are using a 4x4 chassis, it would be relatively simple (depending on if there is a minimal "hump" in the frame) to slide the entire rear suspension (and box) forward 14" on the frame. Then you could use the box as is and less fab work on the cab. Would save a ton of work.
Just an idea.
Just an idea.
