The rebuild of my SD!
I like the text a little on the large side, but for some reason FTE doesn't want to cooperate with me.
Thanks for the compliments guys and for the info on the Firestone bags. I'll check those out. I'll probably wait to do those until I get a plan in place for on board air. This truck eventually needs to be biased towards being a tow truck and a pit truck at the track. I don't have an enclosed trailer or anything terribly fancy for my tools to stay in and I always find myself in the middle of nowhere working on someone else's truck. So I want to have an on board air system large enough to efficiently run a 1/2" impact. If I have to let it refill here and there, that's fine. I just want to be able to take several lug nuts off or get several bell housing bolts out before having to stop for a few seconds. Right now I'm just focused on getting it back and making sure it can get out of its own way. Driving a stock injector/stock turbo truck is for the birds. I can't take it anymore. Especially after going back to my OBS and this rental truck for a little while. Lol
I talked to DJ today. Apparently he got motivated and is working on it through the weekend. He hopes to have it in paint on Monday. We'll see. He got the cab corner welded in today and should be doing the outer bedside and debadging tomorrow. I'll know more Monday when I go look at it.
Bill, the only reason I can't convince myself to do an '05 swap is simply because everyone else does it. I'll make up my mind once I look at it for awhile with the '03 lights.
You will like the '02-'04 Headlights much more than the '05-'07s because they put out better light......there have been several members here that did the '05s and weren't happy with the light output.
I did the '04s in my '99 and installed Sylvania SilverStar bulbs and am very happy with this setup......might try the SS "Ultras" next time though.
I also did the clear side/turn lights from the '04......
You will like the '02-'04 Headlights much more than the '05-'07s because they put out better light......there have been several members here that did the '05s and weren't happy with the light output. I did the '04s in my '99 and installed Sylvania SilverStar bulbs and am very happy with this setup......might try the SS "Ultras" next time though. I also did the clear side/turn lights from the '04......
Hopefully I'm content with the '03 lights. My wallet can't handle too much more of me changing my mind. Lol
Edit- My little bit of sheet metal damage was only $500 from totalling the truck. Lol.
