2002-2007 Ford F350 Truck Power Heated Light Smoked Style Signal & Clearance Light Textured Cap Upgr
VISIT US HERE FOR GREAT PRICES 2002-2007 Ford F350 Truck Power Heated Light Smoked Style Signal & Clearance Light Textured Cap Upgrade Towing Mirror Pair
FREE SHIPPING IN THE LOWER 48 STATES ON ALL ORDERS!!!
These replacement mirrors are just what you need to get your vehicle in good looking form again!
Specifications:
Comes as a PAIR
Fits both LH (Driver Side) & RH (Passenger Side)
Power operation
Heated
Dual Arm
Dual Glass
Manual Extending
Light Smoked Turn Signal Lens with Clearance Light
Textured Caps
Retrofit 2008 and Up Style
Replaces dealer part numbers: 5C3Z-17683-EAA, 5C3Z-17D743-BAA, 5C3Z-17682-EAA, 5C3Z-17D742-BAA, 5C3Z17683EAA, 5C3Z17D743BAA, 5C3Z17682EAA, 5C3Z17D742BAA
180 Degree Swing
10 Hole, 7 Pin Plug
Direct replacements
Built to strict quality control standards
These mirrors make great replacements and have good cost savings over dealer units.
Brand NEW fitting for the following years and models:
2002-05 Ford Excursion Power Heated Light Smoked Style Signal & Clearance Light Textured Cap Upgrade Towing Mirror Pair
2002-07 Ford F250 Truck Power Heated Light Smoked Style Signal & Clearance Light Textured Cap Upgrade Towing Mirror Pair
2002-07 Ford F350 Truck Power Heated Light Smoked Style Signal & Clearance Light Textured Cap Upgrade Towing Mirror Pair
2002-07 Ford F450 Truck Power Heated Light Smoked Style Signal & Clearance Light Textured Cap Upgrade Towing Mirror Pair
Special Note:
This mirror is designed to replace an original mirror with these exact options. If you do not have the options listed, there is a possibility that this mirror may not function properly.
1 Year Warranty
This item is backed by a 1 Year Manufacturers Warranty. In the event this item should fail during intended use, we will exchange the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
This part replaces:
OE #: 5C3Z17683EAA, 5C3Z17D743BAA
Specifications:
Comes as a PAIR
Power operation
Heated
Dual Arm
Dual Glass
Manual Extending
Textured Caps
180 Degree Swing
10 Hole, 7 Pin Plug
Direct replacements
Special Note:
1 Year Warranty
This part replaces:
Need to ask a couple of questions for install on my 2002 Execursion
Specifications:
Comes as a PAIR
Power operation
Heated
Dual Arm
Dual Glass
Manual Extending
Textured Caps
180 Degree Swing
10 Hole, 7 Pin Plug
Direct replacements
Special Note:
1 Year Warranty
This part replaces:
Specifications:
Comes as a PAIR
Power operation
Heated
Dual Arm
Dual Glass
Manual Extending
Textured Caps
180 Degree Swing
10 Hole, 7 Pin Plug
Direct replacements
Special Note:
1 Year Warranty
This part replaces:
What is the best way to contact you? I would like to install these new 08 style TT mirror on to my 2002 excursion but not sure if they will work. I currently have paddle style mirrors with power adjustments, heat and signals. Will these features work with the new replacement mirrors? What about the clearance/running light?
Thanks Michael
Thanks Michael
Thanks Michael
These mirrors would be a direct plug and play replacement for the ones that you have. They have the correct plug ends on them.
2002 Ford Excursion Power Heated Light Smoked Style Signal & Clearance Light Textured Cap Upgrade Towing Mirror Pair at 1AAuto.com
Thanks,
Tony
1999-2007 Ford F350 Truck Power Heated Signal & Clearance Light Telescoping Towing Upgrade Mirror Pa
1Aauto
Vendor Specials, Discounts, Product Announcements & Group Buys
08-18-2014 03:03 PM
1Aauto
06-10-2014 03:26 PM
2002-2005 Ford Excursion Power Heated Light Smoked Style Signal & Clearance Light Textured Cap Upgra
1Aauto
04-29-2014 03:36 PM
2008 - 2010 Ford F250 Truck Power Heated Memory Smoked Style Signal & Clearance Light Textured Cap U
1Aauto
04-04-2013 03:27 PM
