88 5.8 efin into 91 4.9 truck
Sorry for the repost. I put this question in the 87-96 forum befor remembering there was a engine swap section.
If someone has done this or a similar swap please let me know the potential difficulties/problems with the swap. Both trucks are manual trans. Both trucks are complete and run.
Will it be as easy as pulling engine and wire harness unplug and replug in with correct ecm? 88 is 5.8 is extended cab. 91 is 4.9 is standard cab. I have never swapped efi engines only carb so the wire harness and connections are new to me.
fireball 440
05-14-2017 05:20 PM
kckershovel
02-13-2014 06:10 PM
steveoh2222
12-31-2004 02:25 PM
