Advice
Advice
Hello, I have some earlier posts about the problems with my 94.5, looks like it's going to be an engine swap. I want to know from all of your experiences the best way to go. I don't want to get extremely crazy.... I'm thinking around 375 to 400 hp. The truck is a 4x4 extended cab with a 5sp. I m looking at injectors, electric fuel pump conversion, I have a brand new ford hpop... Will this support bigger injectors or do I need to go with another pump ? Jm looking at a melling lpop, I also changed to a single mass clutch a while back but I'm thinking about going back to a dual mass ? What brands are the best for the money spent ?
Don't forget about the basic stuff like intake and exhaust. To get to 400 hp you'll need stage 2 injectors and an upgraded HPOP. A lot of guys like the T500. You will also want a clutch and a turbo because they won't last long at that kind of power level.
EDIT: You would probably like to have an intercooler also because the Egt's can get to high without one.
Dan_Johnston
12-14-2016 09:37 AM
ReBilld
576
04-15-2013 08:38 PM
mongo75
23
04-09-2009 02:10 AM
