1980-1981(?) NOS slider lock control
Most of us have the later style lock [or convert to it], but perhaps someone wants to remain stock...
http://www.ebay.com/itm/NOS-1980-Ford-F100-F250-F350-Truck-Bronco-front-door-latch-lock-unlock-control-/121059662379?pt=Vintage_Car_Truck_Parts_Accessories&hash=item1c2fb7da2b#ht_1900wt_916
1980 Ford F100 F250 F350 Truck Bronco Front Door Latch Lock Unlock Control | eBay
E0TZ-1022169-M .. Control-Door Latch (LH).
Not if you put it on the passenger side upside down, DUH!!! Lol, previous owner actually did that to mine. I had to go through a slew of '80s to finally get one that wasn't broke, then a month later it broke. Somehow he managed to match the exact same color as the other one...
Which is why I'm moving on/back to technology that doesn't break. Being different is not bad and can be good if it works. But when it is prone to breaking....
Chris, when I read this, I was reminded of being told, as a young man, that a "Safety Engineer" was one who wore suspenders as well as a belt to hold up his pants!
From reading these threads, I understand I need to convert my inside locks from slide to the vertical rod pull up design. They are both broken and I can only lock and unlock from the outside. I also understand a hole needs to be drilled in the top of the door to accept the vertical rod. What I do not understand is what else do I need to change out? Does the new vertical rod (I find on lmc.com) just attach to the inner mechanism within my current door or do I need to also swap out the mechanism? I called lmc support and 2 reps have no idea. They appear to be just order takers. Any advise or additional info would be greatly appreciated.
You might find this page to be of help: Door Locks - ?Gary's Garagemahal. From that you can see what parts are different. You will need the **** (431A36) and the rod (21852 & 3) that goes to the ****. Those parts will connect up to your latch and work. But, you will find that down is unlocked and up is locked if you use your current latches. So, if you want it to work the usual way, meaning that down is locked, you will also need the latch itself (21812 & 21813) from a later truck.
Having said that, those are just the basic part #'s, and you need to see the tables below the illustrations to get the complete part #'s if you are ordering Ford parts. But, I can't tell you what LMC is selling.
