bragging milage and cursing the rear main seal
#31
It is a Duraspark body. The parts from a Motrocraft Y block distributor pretty much swap right over and if you use the Duraspark stuff where applicable, you get a Duraspark distributor.
The conversion can also be made with The Y block Motorcraft and Autolite distributors but is slightly, to moderately more involved.
#33
I had some issues on reassembly with the gland nut that goes around the pickup tube into the pump body. I have checked this many many times to verify that I do not have leakage. Even with variable speed none has been found.
The only other unusual situation I have experienced is low oil pressure at idle since I redid all of this. the running pressure is still up there but whereas I formaly had 20psi at hot idle the engine only has 10psi. I still creep to nearly 60 cold and 50 hot on 10W-30 oil while driving but............This one kinda stumps me.
Diesel 724
43
09-09-2011 08:58 PM
matt2491
03-05-2008 06:55 AM
fasttrack ford
06-01-2005 09:00 PM
