Well I did it, bought another obs 7.3!!!
on
1 Post
It has to be a '95 bud. Look about an inch up on the door from the bottom....there is a little body line that runs almost the length of the door. That is something they started in '95. Nothing before '95 had those little lines on the doors. It's newer than you thought it was!
Any body got a link to fix the broken dash problem. If it to much work I'll most likely leave it. Bill you wouldn't happen to have a tumbler and door key set in your parts house?
If it's just the dash pad, replacing it is a piece of cake. All that holds is on are about 8 10mm nuts on studs that go through the dash. It requires removing the radio and dropping the door off the glove compartment, but after that all you need is a 10mm ratchet. I use a 1/4" ratchet and a deep well socket and a nut driver for a couple of the nuts. Pull the old one off, put a new one on, and you're set.
The hardest part is probably going to be finding a good dash pad to put on it.
Glow plugs and relay I'm going to use:94-03 Ford Powerstroke 7.3 Diesel Glow Plug Super Kit - Little Power Shop
Re. the model year, ignore the stickers, the doors, what the seller told you, any carbon-dating, whatever. The VIN determines the model year, by definition.
Photo is waaay too small, and NO detail about the actual brand of the plugs or relay. If you don't no for certain that those are Motorcraft/Beru ZD-11s, DO NOT buy this kit. Quality of relay is anybody's guess. For the same price, you can get a set of ZD-11s and a Western Plow relay.
Thank you, Does anyone know why the engine temp light would be on? It was low on coolent and still it. Drove it all the way home and the temp gauge never came up. I will be looking into it. May throw a T stat on it. Also the ABS light is on. I really need to invest in an Ae system now. The Glow plugs are made by Diesel Rx Brand, made in the USA sold by Jim at rosewood.
Hello gang! Little update!
Last weekend I was up Jim working for the swagger truck and my 96 F250. So this weekend I figured why not work on the other truck I just picked up. I think I'm going to make it sell able and stop there. I'm going to be putting it on craigslist tonight.
After work today I when and picked up a Napa Gpr 109 relay and fuel filter. Then on my way I picked up the truck leaving my jeep in the landscape yard. Truck need a small shot of starting fluid to start. I took it for a spin on the back roads of town. Drove good. One I got it home it was down to business getting stuff figured out. I noticed that the fuel filter light was no longer on. Along with the engine coolant light. I had add 2 gallons of coolant sometime last week I grabbed out of the shop at work. Come to find out. It leaks.
So this is what I have come up with.
Water pump leaking on bottom side some where.
New fuel filter in bowl and very clean. Was a napa one.
Still need glow plugs.
Leaking oil around dip stick tube.
What do u think the truck is worth guys? I'm hopping to get 4 to 4,500 out of it. I don't think that asking to much.
I feel bad for y'all up north... I would freak the hell out if I went to look at a truck and came across all that rust.
Looks like an early '95. It has the early radiator and overflow bottle. Late '95 didn't have a cap on the radiator and had a Degas bottle, not an overflow bottle.
All in all, I bet you'll get quite a few years of use out of it. If the truck was started properly with starting fluid, I wouldn't be too terribly worried about it. The biggest issue with using starting fluid is that if the glow plugs are running when you spray it, it can explode out the intake.
#28
#29
#30
