Torque App on an OBS Powerstroke
#125
#126
#127
Engine Link is the one I have on my iphone. I have not been able to get it working on my PSD yet, but there is someone in the SD forum that has been using it. It seems to work the same as Torque so I'm not sure why it doesn't work. I have used it on my wife's 5.4l without issue. I know that it is connecting to the trucks ECU because it will read the speed and rpms just fine; but everytime I try to check for codes it will cause the engine to almost stall. Or if I try to read ICP, the engine will start to sputter and stumble.
#128
#129
cant connect to PCM
I have had torque for a while and used it on my other (newer gas) vehicles. I tried reading codes on my 97 powerstroke and it killed the motor like I now know it does. I quit it then and there. Then I read more on FTE and I tried to connect just to get some info on the motor. Trouble is I can't connect to the PCM. I used the same adapter I used before on my other vehicles and it lit up when plugged into the powerstroke. It just says searching for protocol. I see on the vehicle profile I can change the protocol. Is this necessary? Any other ideas/suggestions welcome. Thanks gents.
P.S. I have a ELV adapter not the V gate one pictured in this thread.
#130
#131
Does anybody know why this setup works for some trucks and not others?
#133
Well, I was never able to get the Engine Link app to work (other than reading speed and rpms), but now I have an Android device so I bought a BT dongle (same VGate one that Nate has) and the Torque app. I think the BT dongle is bad as it won't connect to the ECU in either the truck or the Expedition. So I tried my wifi dongle with Torque and was able to get it to connect to the ECU, but it said that my ECU does not support PIDs and would not read any data.
#135
Ok, so I was able to mess with it some more today and my problem with the wifi adapter is that it won't stay connected to my phone for more than a minute; but I was able to read ICP for a few seconds before it lost the signal. So right now I just need to contact the ebay seller I bought the BT adapter from and see about getting another one since this one won't connect to the ECU.
