2015 high capacity trailer tow package
Anyone notice this on the order guide?
TRAILER TOW PACKAGE – HIGH CAPACITY (535)
Availability
• Optional on F-350 DRW 4x4 Crew Cab Not available with:
• Pickup Box Delete (66D)
Requires:
• 4.30 Limited-slip rear-axle (X4L)
• 6.7L Power Stroke® Diesel engine (99T)
• 172” WB (8’ box) Includes:
• Front Fender Flare Moldings
• Increase GCW on diesel engine from 31,900 lbs. to 35,000 lbs.
• Max Front Springs
• "Wide track" axle
Looks like this package will give you the "current" F450 from what I can see.
Availability
Requires:
• Max Front Springs
• "Wide track" axle
Think of it like riding a bicycle. The higher numerically the gear the lower it is. So, 4:30's are like putting you bike in a low gear. Very easy to pedal, but your pedaling very fast and going slow. So, on a truck, the engine doesn't have to work as hard to get the load moving, but spins faster using more fuel.
All reviews I've read say "yes it tows 30,000 but it just tows it ok"
