57 F100 9" - 28 or 31 spline?
Some 1968/72 F100 9's have 28 spline axle shafts, some 1968/72 F100 9's have a 9 3/8" ring gear with 31 spline axle shafts.
CAVEAT EMPTOR - Let the buyer beware. If the "1965 3rd member" is from a car, it could have 28 or 31 spline axle (aka differential) gears.
I found the cause of the issue. It looks like in the past a wheel bearing must have came apart and sent a ball bearing down in the pumpkin. After removing the 3rd member I could see damage on both the pinion and ring gears along with metal in the housing.
I ended up pulling a 65 F100 3rd member which was an exact match outside of the C4AW case (1 bar + no filler plug). Backlash is with-in spec so I didn't rebuild or change seals. Everything went together with a breeze and the truck is now running with no rear end noise!!
matt2491
13
08-11-2008 12:40 AM
bsprowl
07-30-2007 01:26 PM
fordxxx
02-11-2006 07:02 PM
