79 I6 swap to V8 or Injected 6
I"m looking at swapping out my 79 straight six for either a carbed V8 (302 most likely) or an injected straight 6. I like the straight 6 quite a bit, so my question is this. If I bought a donor truck with the six in it like this one 1995 Ford F-150 Pickup Truck - Kitchener / Waterloo Cars For Sale - Kijiji Kitchener / Waterloo Canada.
1. Would the newer 6 bolt right in the same way my 79 does?
2. Would the bellhousing be different? I have a 3 spd on the column and this is an auto... I want to keep the 3 speed.
3. It would be a fairly easy swap just to take the engine, all the wiring and exhaust work and throw it in my truck, right?
The blocks are identical except for the mechanical fuel pump on the older blocks, so it will directly bolt up.
You will need to mount the ECM and dash harness in the cab, and to keep it even simpler mount the newer gauge cluster in your dash as well. The less re-wiring you have to do the better.
You will also need to use an electric fuel pump, the 300's need around 45 psi fuel pressure, to keep it simple you could mount the FI trucks tank and sending unit and even use it's harness.
But I would only bother with the swap if you were swapping in an MAF 300 and not a speed density setup.
This isn't a direct swap, I'm just trying to word it as simply as possible, a gauge cluster is definitely not going to bolt in, nor will a fuel tank.
Your still going to need to do quite a bit of wiring and fabrication.
MAF 300's were in 96 and some 95's.
If I were you I'd build up the carbed 300.
Fuel system isn't too bad if you have a donor truck. The 90's rear tank is a bolt in, the fuel lines for a single tank truck make it easy, you don't need to swap dashes. You will have to wire for the PCM and such things. The pivot for the clutch linkage that mounts to the engine is not drilled out or cast properly in the newer blocks. I had to have a special pivot ball made to work in the new block because I had to oversize the hole and thread it. Exhaust will have to be re-worked a little. Love my EFI 300 in my 78'. I added the M5OD trans to which will involve adding a hydraulic clutch setup. The old chassis harness is mostly seperate from the engine harness. You can strip out the engine harness and only need a few hot in run and start kind of connections.
Your best friend will be the ford wiring manual. I just got a hold of them and sorted out the wires. I got an underhood fuse box from a newer expeditionwhich makes like easy cause it will have relays and fuses you can use to interconnect the old chassis harness and the new engine harness with some splicing. I don't remember off the top of my head but I only have like 4-5 relays and fuses and use the 2 exsisting wires from the old trucks ignition switch to actuate relays to power up the computer and fuel pump.
TPS (throttle position)
MAP (Manifold Absolute Pressure)
ECT (Engine Coolant Temp)
IAC (Idle Air Control)
EGR position
EGR vacuum control solenoid
a few ignition control wires
injector wires
O2 sensor
maybe one or two more I forget.....
I can't recall if the 95 trucks still use the thermactor air system for emissions or not but there is a way to get rid of all that stuff. And the obvious alternator and things of that nature.
Fuel Injection is very easy in these trucks. I love my efi 460. As long as it's the rear tank setup its direct bolt in except for the sending unit is the wrong ohm range for the factory guage.
Only two wires to really worry on these trucks and as far as I know they are all PRETTY MUCH the same but dont quote me on it.
Red/Green is hot in run and start
Red/Blue is hot in start only.
Well, it really depends on what it needs- I'd probably be able to do the EFI swap for less than $200 when all's said and done.
