Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F-600 Questions
Old 06-03-2014, 10:05 AM
wagners's Avatar
wagners
wagners is offline
I just purchased a 1992 F600 Crew Cab with the 6.6 and automatic Allison Transmission. I want to make a pick up out of it so I need to shorten the wheelbase and get the back drive shaft cut down. Has anyone done this before and could offer some advice?
The VIN is 1FDNK62P2NVA21354 if anyone has a decoder it would be nice to see what it originally came with versus what is there now. I will post more pics as we go, we just picked up a 1992 dually bed so now it is time to get the frame and drive shaft attended to.
Old 06-03-2014, 12:02 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,596 Likes on 1,301 Posts
It's done all the time.
If the frame rails are straight and the same size front to back, you can simply redrill the frame and move the rear suspension forward.
What type of suspension does it have? Spring or air?
Spring suspensions offer a punishing ride for what you are doing.
As for the drive shaft, once you have a final dimension, you can take that to a driveline shop to have it rewelded, balanced etc. Again, not something you can do at home unless home is a machine shop with a lathe and high powered welding equipment.
If you have to cut the frame, again, higher powered welding equipment (not a 110v Harbor Freight wire welder....) is required, along with proper welding techniques and reinforcing.
Not a job to learn on imo.
Old 06-03-2014, 12:42 PM
gandrimp's Avatar
gandrimp
gandrimp is offline
I will agree with everything 85e150six4mtod posted except the quoted above it should read " Spring suspensions offer a PUNISHING ride for what you are doing."
Old 06-03-2014, 08:52 PM
wagners's Avatar
wagners
wagners is offline
I agree with the punishing ride but I should have my 36ft fifthwheel or 36ft goosneck attached a lot of the time. I took it out for a spin with the enclosed 36ft goosneck and it felt pretty good.
I am assuming from that, that 1500 to 2000 lb pin weight will smooth out the ride. What I have decided after mounting the 8 ft bed I have is too have the front of another bed welded to it. I have 30 inches to the cab after the 8 ft bed is placed so I plan on leaving a 2 inch gap for flex and butt welding the front section of another bed to it.
I say I, but I mean my friend who does body work. So I will have an 8ft dually bed with a 28 inch extension that will provide a nice place to bring up my stacks and provide a nice place for chains binders and misc stuff, while keeping the side view looking like a long bed dually.
I have to raise the bed 5 inches off the frame to get the body lines right so I plan on welding 5x2x48 3/16 tube steel across the frame then mount the bed to that structure. My existing goosneck plate will have to be rasied 7 1/2 inches so that plate will stick through the bed.
What I have to figure out is how to securely mount that 7 1/2 inches above the frame and make it adjustable so my gooseneck ball and my fifth wheel hitch can be rasied or lowered de pending on the trailer I have hooked to it. I have already had all the axles flipped on my trailers because my 1 ton is a 4x4 with 20 inch wheels and everything was to short to clear the bed rails.
I think I will mock it all up with wood and go pull under the fifth wheel and goosneck. then decide which I want more, the body lines to match up or if I want to haul my trailers.
Any ideas or drawings of existing hitch hook ups would be appreciated.
Old 06-03-2014, 09:28 PM
nevrenufhp's Avatar
nevrenufhp
nevrenufhp is offline
You may have lucked out with that one. 92 is when the famous P-pump started showing up on the 6.6/7.8s.
Old 06-03-2014, 09:42 PM
wagners's Avatar
wagners
wagners is offline
What is that and where do I look?
Old 06-04-2014, 12:24 AM
nevrenufhp's Avatar
nevrenufhp
It's the injector pump that made the Cummins 5.9 famous in 94-98 Dodges. The 2 pumps it can be are an MW-pump, or a P-pump. Sure fire way to tell is the numbers on the pump. It starts with PES6, then the next will be the model(MW or P). Either pump has some hot rodding potential.
Old 06-05-2014, 01:19 PM
Fossilman Ford's Avatar
Fossilman Ford
Fossilman Ford is offline
4wd Low
Awesome truck Wagners
I ultimately want to exchange the regular cab on the F-600 I'm trying to obtain and replace it with a crew cab.
Here are some pictures of the truck...
Old 06-05-2014, 01:33 PM
Fossilman Ford
4wd Low
The front of the Beast! I would cut off the snowplow mount
Driver-front hub
the water tank would also go
Stamped VIN tag
total mileage 28,672.8
Info plate about 4x4 equipment
transfer case tag
Old 06-27-2014, 02:05 PM
Fossilman Ford
4wd Low
Anyone know what the transmission code "AA" mean? And the axle code "AG" mean?
Old 08-23-2014, 11:10 AM
DFitzhunter's Avatar
DFitzhunter
DFitzhunter is offline
Best oil for 7.3 F-600 engine
What is the best oil for a 7.3 1989 F-600 Engine. In central Florida, extreme heat conditions, truck is driven very little but sometimes on long runs.
Old 08-23-2014, 11:56 AM
nevrenufhp's Avatar
nevrenufhp
7.3 in an F600? As in a gasser 429? I thought they had either a 429 V8 gas, or 6.6 or 7.8 inline six diesel.
Either engine, I'd say regular ol Shell Rotella 15W40.
  #28
Old 08-28-2014, 12:41 AM
wantahertzdonut's Avatar
wantahertzdonut
wantahertzdonut is offline
Originally Posted by Fossilman Ford
~snipped photos of 4x4 awesomeness~
I have to ask, what kind of fuel mileage does one get in a monster like that? I see these come up for sale once in a while and I'm dying to know!
Country Bumpkin
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
34
08-16-2019 01:10 PM
Eh1992xlt
08-09-2018 10:00 PM
ACADguy
2015 - 2020 F150
12-03-2016 01:39 PM
Customz
11-26-2004 11:49 AM
mundamanu
08-14-2004 10:07 AM
Quick Reply: F-600 Questions
