Michigan Chapter Join Chapter, Leader: Toyman
IMPORTANT Michigan BS - Required Reading!
Old 05-05-2015, 02:11 PM
TheBigBee's Avatar
TheBigBee
TheBigBee is offline
Lol nice You deliver? I dont have a delivery mobile anymore Frankenbee down!
  #7862
Old 05-05-2015, 02:14 PM
Toyman's Avatar
Toyman
Toyman is offline
It would seem, by reason of deduction that you need an hpop. What do the 7.3L guru's say?
  #7863
Old 05-05-2015, 02:19 PM
SDElwood's Avatar
SDElwood
SDElwood is offline
But I'll still pay for all three, it's cool man.
  #7864
Old 05-05-2015, 02:20 PM
TheBigBee's Avatar
TheBigBee
Nobody is really responding to my thread just new guys.
  #7865
SDElwood's Avatar
SDElwood
SDElwood is offline
Say about what?
  #7866
Old 05-05-2015, 02:24 PM
Toyman's Avatar
Toyman
Toyman is offline
Andrews truck Mike. You are having a hard time keeping up today.....
  #7867
Old 05-05-2015, 02:30 PM
SDElwood's Avatar
SDElwood
SDElwood is offline
Aww crap. I just always jump to last page. I'm supposed to read something?
  #7868
Old 05-05-2015, 02:32 PM
Toyman's Avatar
Toyman
Toyman is offline
not supposed to.....unless you want to follow the conversation and all of it's meandering that we do with it.....
  #7869
Old 05-05-2015, 02:33 PM
TheBigBee's Avatar
TheBigBee
Frankenbee died on me going down the highway. Fuel is good, rpm are good so CPS is good, Injector Buzz test is good so IDM is good, engine oil pressure is good so LPOP is good but I have no ICP so by reason of thinking my HPOP is bad. Only other thing to check is pull the Hpop lines and try to put compressed air into it to see if I can hear a leak from an injector oring. But I am doubting that as I would think all the injectors would have to have bad ones for absolutely 0psi on the ICP.
  #7870
SDElwood's Avatar
SDElwood
SDElwood is offline
Ok I've read what I could. I wouldn't jump to the HPOP conclusion.
  #7871
Old 05-05-2015, 02:35 PM
SDElwood's Avatar
SDElwood
SDElwood is offline
Died? Just died like you shut off the key? I mean with the history of this truck, and all of the electrical gremlins, I'd start there. Do you have a multi-meter? Can you check voltage coming in?
  #7872
Old 05-05-2015, 02:36 PM
TheBigBee's Avatar
TheBigBee
Oh and i cleaned and test the IPR and that is working as it should ohmed out to around 10-11. Tried the unplug the ICP trick as well.
  #7873
Old 05-05-2015, 02:37 PM
TheBigBee's Avatar
TheBigBee
Ya I am getting voltage everywhere it is supposed to be. When I unplug the ICP the computer starts reading the default 2000+psi. I geuss I could pull the ICP and crank it over to see if I get a fountain out of the hole. That would be a real pressure test.
  #7874
Old 05-05-2015, 02:38 PM
TheBigBee's Avatar
TheBigBee
yes like the key was shut off doing 70.
  #7875
Old 05-05-2015, 02:41 PM
SDElwood's Avatar
SDElwood
SDElwood is offline
That's usually CMP sensor...
Quick Reply: IMPORTANT Michigan BS - Required Reading!
