IMPORTANT Michigan BS - Required Reading!
Check and see if you get fuel pressure, easy way is to spray some starting fluid to see if it fires. I have a fuel pressure gauge but leaving town today as soon as I can get out of work.
Staying at Silver Creek Chad!
Brakes done, trip into town done, stickers done, fuel done, vacuum done, bath done, flags done, now just have to shower and pack.
Chad what time are you getting in?
Speaking of brakes, I need some help. I sent a picture to Putz, but he couldn't help me. Is this a rotor or an ABS sensor?
I am outta here. You have a good weekend. I'll be north, but no cell service of any kind at the cabin. I do get service now and then, so if something comes up and you need something, send a text. Cheers!
Well that and I don't have cell service anywhere anymore... I like my phone off. I am working towards no cell phone... I give myself a couple weeks, and then I won't ever turn it on again.
Is there gas in it? Sorry, but in my line of work, it's the first question.
OK first Mike---- Yes Fuel is in the tank and all the way to rails
I will look at the grounds again since i had the Harness out and why not
I will look into the pinout of the harness and see if I can figure out how to check the injectors- Do I need to check all 8 getting to the Pass ones is a bitch.
also when I got it to fire up with the carb cleaner it would only run if I advanced the distributer clockwise. Am I off just 1 or 2 teeth? and maybe that is the issue?
