Michigan Chapter Join Chapter, Leader: Toyman
IMPORTANT Michigan BS - Required Reading!
Old 05-05-2015, 02:44 PM
TheBigBee's Avatar
TheBigBee
TheBigBee is offline
I am reading 150+ rpm when cranking though so that rules the cps/cmp sensor out doesn't it?
  #7877
Old 05-05-2015, 03:02 PM
Toyman's Avatar
Toyman
Toyman is offline
Way cheaper than a hpop
  #7878
Old 05-05-2015, 03:10 PM
TheBigBee's Avatar
TheBigBee
Alright I ordered a new CPS from Clay we will see what it does but I am not holding my breath. Also got the replacement drain plug for the water separator on the Excursion to offset the shipping cost.
  #7879
Old 05-05-2015, 04:21 PM
Fordman96's Avatar
Fordman96
Fordman96 is offline
There used to be a doc.google page floating around about the no start tree for diesels. I'll find it when I get home because I bet I can't link on mobile.
  #7880
Old 05-05-2015, 04:29 PM
TheBigBee's Avatar
TheBigBee
I have the document I posted it up here when I first did the swap. I looked at it but everything checks out except for icp.
  #7881
Old 05-05-2015, 05:24 PM
jimmyv13's Avatar
jimmyv13
jimmyv13 is offline
Originally Posted by Chad149
Question for you Rich?
What's your opinion of Goodyear marathons for trailers? The China bombs on our gooseneck are dropping like flies. Lost one in March, another two this weekend (still holding air, but round is not a word I'd use to describe them). Debating mentioned Goodyear's or perhaps some g rated Sailun S637.
I went though a tire purchase for our TT last summer and after a few weeks of researching, I finally settled on Maxxis M8008's from realdealtires.com Best prices I found. I had Belle Tire mount them when they arrived.
I read the Goodyear Marathon was made in China, so I went a different route. The guys on the Keystone forum seem to really like the Maxxis tires.
  #7882
Old 05-05-2015, 06:00 PM
JOHN2001's Avatar
JOHN2001
JOHN2001 is offline
Fuel bowl heater? I'm just spit balling here without really reading everything.
I got the 460 running today!!! Sounds healthy!!!!
  #7883
Old 05-05-2015, 06:24 PM
jimmyv13's Avatar
jimmyv13
jimmyv13 is offline
Isn't there something in the front cover of the 7.3 that causes low oil pressure resulting in a no start?
  #7884
Old 05-05-2015, 06:42 PM
JOHN2001's Avatar
JOHN2001
JOHN2001 is offline
CPS is on the front of the engine, ICP is on the back of the HPOP fuel bowl heater is in the fuel bowl with a fuse in the cab. All 3 things can stop a 7.3 in their tracks
Edited for correction
  #7885
Old 05-05-2015, 07:13 PM
Toyman's Avatar
Toyman
Toyman is offline
I have some shorty headers from L&L nickel plated if you want to let it breath John
  #7886
Old 05-05-2015, 07:16 PM
Chad149's Avatar
Chad149
Chad149 is offline
Jay ordered some of the Goodyears this afternoon. He gets vendor pricing so it wasn't too painful. His price on Carlisle tires is really good, but wanted something better. If these don't work out we're going to try LT tires next.
Don't be afraid to call if you need tires mounted either.
Originally Posted by JOHN2001
CPS is on the front of the engine, ICP is on the back of the engine, fuel bowl heater is in the fuel bowl with a fuse in the cab. All 3 things can stop a 7.3 in their tracks
Fuel heater this time of year? Does that fuse power something else more important?
  #7887
Old 05-05-2015, 07:38 PM
JOHN2001's Avatar
JOHN2001
JOHN2001 is offline
Exhaust is going to exit out the side of the hood. I'm going to have to build them.
Ya really never know when the fuel bowl heater will jump up and bite you. It shouldn't but...
  #7888
Old 05-05-2015, 08:47 PM
Fordman96's Avatar
Fordman96
Go out the fenders john like the camaro on "Street Outlaws" or do a cowl hood and stick them out each side of the cowl
  #7889
Old 05-06-2015, 06:09 AM
JOHN2001's Avatar
JOHN2001
JOHN2001 is offline
It'll be more like the elcamino from the same show. With the design of the truck there going to have to come out of the sides of the hood. I've got a lot of work to do before I get that far though. Physical getting the front clip around the engine is going to be a big task.
  #7890
Old 05-06-2015, 07:19 AM
TheBigBee's Avatar
TheBigBee
Ok I think we are heading off in the wrong direction diagnosing my truck. I have no ICP! it cranks and shows rpm and buzz tests fine. I dont know if anything mentioned really has anything to do with the ICP right?
Quick Reply: IMPORTANT Michigan BS - Required Reading!
