1995 mazda b4000 4wd light 6x blinking.
Old 12-31-2013, 05:48 PM
Tractorman1215's Avatar
Tractorman1215
Tractorman1215 is offline
So i just bought a b4000 pickup 5spd because my f150 as some of you know is being a PIA. Anyway the truck has eletrical 4x4 with manual hubs. When i turn the switch nothing happens. The 4wd/4wd low lights both flash 6x then go off then flash again while running , driving, koeo, anytime like an obd1 check engine light code flashing. Anyway i checked the wiring for the 4wd switch no power, went to the fuse interior no pwr, went to the engine fuse box power. You don't hear the transfer case engage at all as well. Any suggestions appreciated.
Old 01-01-2014, 12:42 AM
Frozen_Joker's Avatar
Frozen_Joker
Frozen_Joker is offline
A relay maybe? You have no power past the under hood fusebox if I read right. Well that would mean the issue is there at that fusebox.
Old 01-01-2014, 10:46 AM
Tractorman1215
Sorry i was wrong i do have power to the interior fuse box. Just not the the switch.
Old 01-01-2014, 11:37 AM
Frozen_Joker
So no power to the switch from the fuse box? Bad switch maybe? Or you could have a lose or broken wire that goes to the switch. Or you could have power to the switch but no power going from the switch to the transfercase. So that would still indicate a possible switch problem.
Old 01-01-2014, 02:02 PM
Tractorman1215
I have no pwr to the switch. I jumped the switch with power from the battery however it did nothing when i switched to 4hi/lo, i jumped the light for the switch light came on tried jumping the signal wire for the tcase nothing happened.
Old 01-01-2014, 03:31 PM
Tractorman1215
Does anyone have the wiring diagram? I printed one out but its so fliping confusing. All i need is the 4wd circuit one. Much apprecitated.
RShaips
1997-2006 Expedition & Navigator
48
09-28-2020 07:08 PM
jejenkins
10-17-2013 09:55 AM
BigHazard
01-31-2011 05:45 PM
rcdriver11
1997 - 2003 F150
06-05-2010 01:57 PM
wobblez
10-24-2009 09:25 AM
Quick Reply: 1995 mazda b4000 4wd light 6x blinking.
