Janurary FTE Missouri chapter BS & chat thread, all welcome.
#121
#123
#126
#127
#128
#129
wifes car won't start either battery is dead jumped it let it run for 30 mins or so turned it off went out a hour or so later wouldn't start again. Guess its time for a new battery i do know the one that is in it is a little on old side. Still jumps just fine though. Funny thought she was all proud of her car after she backed it out of the driveway yesturday to go to work after i had told her she probably wouldn't make it till i shoveled it all off. She proved me wrong (and made me hate that little olds even more) but she got paid back coming home when it got stuck in the ROAD turning off of campbell onto our street.
#130
Header Bolts
Spraying the lines with carb cleaner will let you know you have a leak because the idle speed will increase.
Do not forget anti-seize compound on the header bolts or just some grade 8 bolts called (flange bolts) cause the head kinda looks like a washer and have you looked into those Nord-Lock lock washers?
Morning Missouri.
Morning Missouri.
I returned the APR header bolts and bought Summit's best. They are Nickel Plated Steel with a washer that prevents them from backing out. There is also Circlips to hold the washers on.
It is now -5 degrees with a high of 31 and clear skies.
Take care.
Boon
P.S. I also purchased the Copper Crush Washers but having a bit of trouble finding Grade 8 5/8-11 Bolts for the back of the heads.
#131
Check with "Fastenal", they always have what ever I need as far as hardware (nuts, bolts metric and standard), steel stock, Dewalt tools, HD cutting and drilling tools.
Home | Fastenal
Home | Fastenal
#132
Alan I've had MANY..... cold mornings that I wanted to take Ka'Bluey out for a drive, and he just didn't have it in him. That carb needs a choke!
So how is everybody doing? The cold weather has bade it's way east, it's only up to 11 degrees here, it was 8 when I got up at 6am. Looks/feels like a good day to hang around inside the house.
Unk Bob
Unk Bob
#134
