strange problem
strange problem
I am having a strange problem..here goes.. my truck will start right up in the mornin and I drive a half mile to the store, shut it off, come back out and crank it. it fires for a split second and dies.. dont matter how long you crank it, it seems to take about 10 minutes before it will start again. today it died while running, pretty much the same thing. I changed the fuel filter, as it acts like its a fuel problem ??
Thanks
97 f250 5.8 I,ll check the next time it does it, its happened 3 times in 2 months, and so far just early in the morning. today was the first time while pulling away from a stop sign, so its getting worse. I don't mind 10 or 15 minutes in a parking lot. but the center of the street ,not so much
Its not a weak spark, Zaped me pretty good with gloves.
I am thinking the pressure regulator is my next move, but the symtoms don't seem to match.
I'm almost positive it's a fuel thing..
could it be the idle control valve??
I'll see if i can find a gauge..
Money is tight in this weather.
I never got around too running a fuel pressure test yet.. they don't rent them here.. But , I did switch the relay out with horn relay, and , so far all is well.
If this holds true it will be the cheapest repairs ever..hope this helps others in search of a answer on the computer.
I know $20 can be a lot of cash to drop when money's tight (I've been there a few times!) but if you ever do need a cheap fuel pressure gauge, Harbor Freight has this one:
Fuel Pressure Tester & Fuel Injection Pump Tester
It's on sale a lot, I have one and it does fit our trucks. I had to use thread sealer on the gauge fitting but for $20 I don't really give a damn. Only thing that sucks is there's no valve to bleed off pressure when you're done, you just have to unscrew it and let it **** a bit. Just don't do it when the engine's hot and it'll be fine.
1986stepsidef150
06-19-2012 05:41 PM
tjones2269
12-04-2009 01:00 PM
Dave88F250
13
08-09-2005 09:59 PM
