Slight Miss / Rough Idle
2003 F150 5.4 72852 miles
I have a Rough Idle & sometimes a hesitation or stumble on acceleration.
I cleaned the MAF & IAC motor & Air & Fuel Filters are new. I got a 20890 scanner & ran test 6 53 as suggested in many posts by BlueGrass. Here are My results & what They Convert to.
1 00F5 .3675
2 0051 .1215
3 0000
4 0000
5 00A3 .2445
6 0000
7 0000
8 0000
I'm guessing the cop's are ok & probably need plugs? I was hoping to just swap a coil. Too cold to do plugs & truck won't fit in my garage. Thanks
1 00F5 .3675
2 0051 .1215
3 0000
4 0000
5 00A3 .2445
6 0000
7 0000
8 0000
Cylinder 1 decimal count is 245.
#2 = 81.
#5 = 163.
What does the scanner say? High, low or ok!
Cylinder 1 is the first to address.
The rest are low.
Make some changes to those cylinders then run awhile.
It takes some time to refresh the counts.
Remember if these are not setting codes there under the radar so your nit picking the system.
A zero count on all cylinders is very good but may not always hold over time and still not cause any problems from very low counts.
Bad gas could be the cause then go away after awhile.
Good luck.
#2 = 81.
#5 = 163.
The rest are low.
Good luck.
#2 = 81.
#5 = 163.
The rest are low.
It take some time to refresh the counts.
Good luck.
#2 = 81.
#5 = 163.
The rest are low.
Good luck.
